Mi lenguaje de programacion lima
en lima se pueden hacer cosas como estas
# MKF7.lima
# abstract:
#   because cant conect the debugger with the code this emulates it
# and because that "if dont have the tools of MKF7 make it by youself"
# please execute this before make anything in the uefi , basically its the uefi base
# save the code to the 0 segment (generally the lima base)
org
0
org
1
# for restore uefi and dont lose nothing
sendmw uefi_prototypes()
sendmw uefi_boot()
sendmw uefi_shutdown()
__endprog__
### ! A NEW SECTION WILL BE START SOON
######! MKF7 variables convertion
[intersegmental]
message uefi_prototypes()
[globalize]
var
    _returned
    prototype
[globalize]
var
    _action
    prototype
[globalize]
var
    _data1
    prototype
[globalize]
var
    _data2
    prototype
[globalize]
var
    exit from boot services?
    0
[globalize]
var
    uefi recover segment number
    1
[globalize]
var
    _@zip.current_archive
    "Z"
[endmsg]
######! prototypes
# prototype for uefi_fs
[prototype]
message uefi_fs()
    prototype
[endmsg]
# prototype for uefi_arr
[prototype]
message uefi_arr()
    prototype
[endmsg]
# prototype for efishell
[prototype]
message efishell()
    prototype
[endmsg]
# prototype for uefi_boot
[prototype]
message uefi_boot()
    prototype
[endmsg]
# prototype for uefi_shutdown
[prototype]
message uefi_shutdown()
    prototype
[endmsg]
# prototype for uefi_reset
[prototype]
message uefi_reset()
    prototype
[endmsg]
# prototype for uefi_exit_boot_services
[prototype]
message uefi_exit_boot_services()
    prototype
[endmsg]
######! built-in MKF7 messages but implemented here
# intersegmental for make it a global message
###! shell commands
[intersegmental]
message shell_command()
#jt
#    do_echo
if
    @ScratchVar(_action)
    "ls"
section
do_ls
    # setuping
    var
        i
        0
    # get the array of the files
    echo "in ls"
    mov
        @eax
        "/glob -gtv -array_startswith"
    mov
        @bx
        "Z>"
    %^"!p"
    var
        list
        @ScratchVar(_returned)
    echo list
__endprog__
__endprog__
section
do_echo
    #echo "in echo"
    var
        msg
    var
        msg
        5
    #echo msg
__endprog__
[endmsg]
###! uefi misc functions
[intersegmental]
message uefi_arr()
    if
        "0x0"
        var
            gx
            Console.SizeX
        var
            gx
            4
        var
            gx
            2
        var
            gy
            Console.SizeY
        var
            gy
            2
        #gotoxy gx gy
        cecho "MKF8"
        button_echo "the best know firmware solution builded in lima"
[endmsg]
###! net
[intersegmental]
message uefi_net()
    section
    Main
    var
        .cnd
        (@ScratchVar(_action)=="0x01")
    jt
        .recive
    var
        .cnd
        (@ScratchVar(_action)=="0x02")
    jt
        .send
    __endprog__
    # recive
    # Summary:
    # 	recive a content from a url
    # Params:
    # 	@_data1: the url
    #   @returned: the return value
    # Registers used:
    #   @eax: for the commands
    #   @bx: the data send
    section
    .recive
        mov
            @eax
            "/get-url"
        mov
            @bx
            @ScratchVar(_data1)
        %^"!p"
            # <- esto devuelve automaticamente el _returned
        if
            @ScratchVar(@ax)
            "unsupported"
            mov
                _returned
                "falied to fetch"
    __endprog__
    # MyFunction
    # Summary:
    # 	send a data from a server
    # Params:
    # 	@_data1: the url
    #   @_data2: the data to send
    # Registers used:
    section
    .send
        mov
            @eax
            "/send-set-url"
        mov
            @bx
            @ScratchVar(_data1)
        %^"!p"
        mov
            @eax
            "/send-url"
        mov
            @bx
            @ScratchVar(_data2)
        %^"!p"
        if
            @ScratchVar(@ax)
            "unsupported"
    __endprog__
[endmsg]
###! diskload actions
[intersegmental]
message load_files()
    echo "loading files..."
    jump
    Main
    # only vfat12 , the subdirs cant be load
    # this loads the files of your real pc in the path where is the uefi executable and coppy it to the
    # Z hard disk
    # Main
    # Summary:
    # 	the copy main
    # Params:
    # 	@(your files in the fd dir): for coppy to the virtual disk
    #   @(obiusly your personal files if you want): but is necesary for can put your files in the uefi
    section
    Main
        # note: all changes maked to the files cant affect to the real file because this loads a
        # coppy and not the real files, and lima only allows read but not write files and directorys
        var
            file_to_load
            0
        # get files count in the dir
        mov
            @eax
            "/dir countf"
        %^"!p"
        var
            max_files
        var
            max_files
            1
        jump
        load
    __endprog__
    # load
    # Summary:
    # 	loads the files to the disk
    # Params:
    # 	@max_files: max files number
    #   @file_to_load: the start point of the files array to load
    section
    load
        # declare vars
        var
            name
            prototype
        var
            content
            prototype
        # get file information
        # file name
        mov
            @eax
            "/file_gName"
        mov
            @bx
            file_to_load
        %^"!p"
        var
            name
        # file content
        mov
            @eax
            "/file_gContent"
        mov
            @bx
            file_to_load
        %^"!p"
        var
            content
        # create file
        mov
            "Z->"(..)name
            content
        echo  "file "(..)name(..)" has been loaded."
        var
            .cnd
            (file_to_load==max_files)
        var
            file_to_load
            1
        jf
            load
            # next file
    __endprog__
[endmsg]
###! fs actions
[intersegmental]
message uefi_fs()
    section
    main
    var
        .cnd
    jt
        .uefi_current_fs_letter
    var
        .cnd
    jt
        .uefi_file_write
    var
        .cnd
        (@ScratchVar(_action)=="0x03")
    jt
        .uefi_file_rename
    var
        .cnd
        (@ScratchVar(_action)=="0x04")
    jt
        .uefi_file_coppy
    var
        .cnd
        (@ScratchVar(_action)=="0x05")
    jt
        .uefi_file_get
    echo "invalid file action"
    __endprog__
    # uefi_current_fs_letter
    # Summary:
    # 	gets the letter of the fs driver
    # Params:
    # 	nah
    section
        mov
            _returned
            @ScratchVar(_@zip.current_archive)
    __endprog__
    # uefi_file_write
    # Summary:
    # 	writes a file
    # Params:
    # 	@_data1: file name (including path)
    #   @_data2: file content
    section
    .uefi_file_write
        mov
            @ScratchVar(_@zip.current_archive)(..)">"(..)@ScratchVar(_data1)
            @ScratchVar(_data2)
    __endprog__
    # uefi_file_rename
    # Summary:
    # 	renames a file
    # Params:
    #   @_data2: new name
    section
    .uefi_file_rename
        mov
            @ScratchVar(_@zip.current_archive)(..)">"(..)@ScratchVar(_data2)
            @ScratchVar(@ScratchVar(_@zip.current_archive)(..)">"(..)@ScratchVar(_data1))
        mov
    __endprog__
    # uefi_file_coppy
    # Summary:
    # 	coppy a file
    # Params:
    #   @_data2: file dest name
    section
    .uefi_file_coppy
        mov
            get{@ScratchVar(_@zip.current_archive)(..)">"(..)@ScratchVar(_data2)}
    __endprog__
    # uefi_delete_file
    # Summary:
    # 	deletes a file
    # Params:
    # 	@_data1 : the file name with path and extension
    section
    .uefi_delete_file
        mov
            get{@ScratchVar(_@zip.current_archive)(..)">"(..)@ScratchVar(_data1)}
    __endprog__
    # uefi_file_get
    # Summary:
    # 	get a file
    # Params:
    # 	@_data1: file full name
    section
    .uefi_file_get
        mov
            _returned
            @ScratchVar(get{@ScratchVar(_@zip.current_archive)(..)">"(..)@ScratchVar(_data1)})
    __endprog__
[endmsg]
###! loads a segment from the uefi
[intersegmental]
message uefi_load()
[endmsg]
# shutdowns the system
[intersegmental]
    __endprog__
[endmsg]
# reset the system
[intersegmental]
    sendmw uefi_boot()
    sendmw uefi_segment_setup()
[endmsg]
# exit from bootservices
[intersegmental]
    mov
        1
    org
    0
    # because the messages execute it as a independence code so , kill the orgiinal uefi segment (0) but
    # dont worry a security coppy its mounted in the segment 1 for this cases
[endmsg]
###! the uefi shell
[intersegmental]
message efishell()
    jump
    loop
    section
    loop
    writel "Shell> "
    var
        command
        ReadLine
    var
        .cnd
        (command=="exit")
    jt
        .exit
    mov
        _action
        command
    sendmw shell_command()
    jump
    loop
    section
    .exit
    __endprog__
[endmsg]
###! the uefi routine
[intersegmental]
message uefi_boot()
    mov
        _action
        "0x0"
    sendmw uefi_arr()
    sleep 1
    sendmw load_files()
    jump
        main
    section
    main
        mov
            0
    jump
    loop
    section
    loop
    writel "Boot From: "
    var
        prompt
        ReadLine
    if
        prompt
        "blk-1"
        # the blk -1
        sendmw efishell()
    jump
    loop
[endmsg]
que les parece mi lenguaje, pronto subire el codigo de una herramienta con interprete y compilador a github
yo aun no manejo bien la programación, de hecho estoy ahorita mismo estudiando pascal con un libro que me encontre por ahi, desde luego me parece interezante tu proyecto.
¿cuales son tus intenciones con este lenguaje?
¿que capacidades o para que esta diseñado?
es un lenguaje como js, pero con algunas cosas , este es el codigo del lenguaje
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
namespace LimaInterpreter
    class Lima // literary the "lima" objet , is very portable , no?
        // apenas puse esto aqui por que olvide que en lima son globales estos diccionarios
        public Dictionary<string, string>
         lima_variables // the variable "lima variables" in turbowarp
        new Dictionary<string, string>();
        public graphichsMode gop = new graphichsMode();
        public bool trueflag = false;
         globvars
        public int Line_to_execute = 0; // literary the name says all
                                        // there variable too exist in the lima objet
        public Dictionary<int, int> popback = new Dictionary<int, int>();
        public Dictionary<int, string> segments = new Dictionary<int, string>();
        public string[] blocks_to_execute;       // other lima turbowarp reference
        public struct Lima_Ex_Affected
            public int type;
            public string id;
            public string new_value;
        public struct LimaExeption
            public bool CloseProgram;
            public int line;
            public bool FromVariable;
            // from variable if true params
            public string varname;
            public int from_mem_direction;
            public int to_mem_direction;
            public Dictionary<int, Lima_Ex_Affected> affected_zones;
            public void ShowExecption()
                int scroll = 0;
                while (true)
                    string line_sep = ""; // for the "---------------------"
                    for (int i = 0; i < Console.BufferWidth; i++)
                        line_sep = line_sep + "-";
                    Console.Clear();
                    Console.WriteLine("line: " + line.ToString());
                    Console.Write(line_sep);
                    for (int i = scroll; i < (scroll + Console.BufferHeight) - 5; i++)
                        if (affected_zones.ContainsKey(i))
                            Console.WriteLine("type:" + affected_zones[i].type.ToString() + " @" + affected_zones[i].id + "\t->\t" + affected_zones[i].new_value);
                        else
                            Console.WriteLine("");
                    Console.WriteLine("if you dont know what is this , is just a Lima Exepction Development tool");
                    ConsoleKeyInfo Key = Console.ReadKey(true);
                    if (
                        Key.Key == ConsoleKey.UpArrow
                        scroll--;
                    if (
                         Key.Key == ConsoleKey.DownArrow
                        scroll++;
        public string
            AskForMessageIntoSegment
                string msg
            for (int i = 0; i < segments.Count; i++)
                if (
                    segments[i].Contains("[intersegmental]\nmessage " + msg)
                    string[] sr = segments[i].Split("[intersegmental]\nmessage " + msg);
                    string[] ara_ara = sr[1].Split("\n[endmsg]");
                    return ara_ara[0];
            return "";
        public string
        LimaSyntax
        string e,
        bool debug
            if (
                    e.Contains("(..)")
                string[] split = e.Split("(..)");
                string syntax = "";
                foreach (var item in split)
                    syntax += LimaSyntax(item, debug);
                return syntax;
            else if (
                e.StartsWith("(") && e.EndsWith(")")
                string ifcond = e.Substring(1, e.Length - 2);
                if (
                    ifcond.Contains("==")
                    string[] split = ifcond.Split("==");
                    if (
                        LimaSyntax(split[0], debug) == LimaSyntax(split[1], debug)
                        return "true";
                    else
                        return "false";
                if (
                    ifcond.Contains("!=")
                    string[] split = ifcond.Split("!=");
                    if (
                        LimaSyntax(split[0], debug) != LimaSyntax(split[1], debug)
                        return "true";
                    else
                        return "false";
                return "false";
            else if (
                    e.StartsWith("\"") && e.EndsWith("\"")
                return e.Substring(1, e.Length - 2);
            else if (
                lima_variables.ContainsKey(e)
                return lima_variables[e];
            else if (
                e.StartsWith('&')
                return e.Substring(1);
            else if (
                e == "Scratch.GetYear"
                return (DateTime.Now.Year).ToString();
            else if (
                e == "Scratch.GetMonth"
                return (DateTime.Now.Month).ToString();
            else if (
                e == "Scratch.GetDay"
                return (DateTime.Now.Day).ToString();
            else if (
                e == "Scratch.GetHour"
                return (DateTime.Now.Hour).ToString();
            else if (
                e == "Scratch.GetMinute"
                return (DateTime.Now.Minute).ToString();
            else if (
                e.StartsWith("@ScratchVar(")
                string er = e.Substring(12, e.Length - 13);
                if (
                globvars.ContainsKey(er)
                    return globvars[er];
                return "";
            else if (
                  e == "Scratch.GetSecond"
                return (DateTime.Now.Second).ToString();
            else if (e == "nullptr")
                return "";
            else if (e == "NULL")
                return "";
            else if (
                e == "@debug"
                return debug.ToString();
            else if (
                e == "ReadKeyWait"
                return Console.ReadKey(true).KeyChar.ToString();
            else if (
                e == "ReadLine"
                string em = Console.ReadLine();
                return em == null ? "" : em;
            else if
        e.Contains("(->)")
                string[] split = e.Split("(->)");
                if (
                    split[1].StartsWith("[") &&
                    split[1].EndsWith("]")
                    string item = split[1].Replace("[", "");
                    item = item.Replace("]", "");
                    string[] array = lima_variables[split[0]].Replace("\r", "").Split("\n");
                    if (array.Length < Convert.ToInt32(lima_variables[item]))
                        return array[Convert.ToInt32(lima_variables[item])];
                    return "undefined";
            return e;
        public async void
            Execute
            string e,
            bool debug
            if (e.StartsWith("echo "))
                Console.WriteLine(LimaSyntax(e.Substring(5, e.Length - 5), debug));
            if (e.StartsWith("cecho "))
                string texto = LimaSyntax(e.Substring(6, e.Length - 6), debug);
                int x = (Console.WindowWidth - texto.Length) / 2; // Calcula la posición horizontal
                int y = Console.WindowHeight / 2; // Calcula la posición vertical
                int oldx = Console.CursorLeft;
                int oldy = Console.CursorTop;
                Console.SetCursorPosition(x, y); // Mueve el cursor al centro
                Console.WriteLine(texto);
                Console.CursorLeft = oldx;
                Console.CursorTop = oldy;
            if (e.StartsWith("button_echo "))
                string texto = LimaSyntax(e.Substring(12, e.Length - 12), debug);
                int y = Console.WindowHeight - 1; // Calcula la posición vertical
            else if (e == "%^\"!p\"")
                if (
                   globvars["@eax"] == "/file_gName"
                    IEnumerable<string> names = Directory.EnumerateFiles(globvars["@dircurrent"]);
                    string[] nrt = names.ToArray();
                    globvars["_returned"] = Path.GetFileName(nrt[Convert.ToInt32(globvars["@bx"])]);
                else if (
                    globvars["@eax"] == "/glob -gtv -array_startswith"
                    string array = "";
                    foreach (var item in globvars.ToArray())
                        if (item.Key.StartsWith(globvars["@bx"])) array += item + "\n";
                    globvars["_returned"] = array;
                else if (
                    globvars["@eax"] == "/dir countf"
                    globvars["_returned"] = nrt.Length.ToString();
                else if (
                   globvars["@eax"] == "/file_gContent"
                    globvars["_returned"] = File.ReadAllText(nrt[Convert.ToInt32(globvars["@bx"])]);
                else if (
                    globvars["@eax"] == "/get-url"
                    string url = globvars["@bx"];
                    using (HttpClient client = new HttpClient())
                        try
                            // Enviar una solicitud GET y obtener la respuesta
                            HttpResponseMessage response = await client.GetAsync(url);
                            // Asegurarse de que la solicitud fue exitosa
                            response.EnsureSuccessStatusCode();
                            // Leer el contenido de la respuesta como una cadena
                            string content = await response.Content.ReadAsStringAsync();
                            globvars["_returned"] = content;
                        catch (Exception ex)
            else if (e.StartsWith("writel "))
                Console.Write(LimaSyntax(e.Substring(7, e.Length - 7), debug));
            else if (e.StartsWith("color "))
                string er = e.Substring(6, e.Length - 6);
                string[] colors = er.Split(" ");
                string foreground = LimaSyntax(colors[0], debug);
                string background = LimaSyntax(colors[1], debug);
                Console.BackgroundColor = ConsoleColor.Black;
                Console.BackgroundColor += int.Parse(background);
                Console.ForegroundColor = ConsoleColor.Black;
                Console.ForegroundColor += int.Parse(foreground);
            else if (
                e.StartsWith("sendmw ")
                int line_to = Line_to_execute;
                Dictionary<int, int> recover_popback = popback;
                //Console.WriteLine(e);
                ExecuteLimaScript(AskForMessageIntoSegment(e.Substring(7, e.Length - 7)), debug);
                Line_to_execute = line_to + 1;
                popback = recover_popback;
            else if (
                e == "cls"
                Console.Clear();
            else if (
                e.StartsWith("sleep ")
                Thread.Sleep(int.Parse(LimaSyntax(e.Substring(6, e.Length - 6), debug)) * 1000);
            return;
        public string
            Operate_With
                string operator1,
                string a,
                string operator2
            if (a == "=") return operator2; // the equal simbol
            if (a == "+=") // the sum simbol
                if (
                    int.TryParse(operator1, out int value1) == false // if the operator1 is a text
                    if (
                        int.TryParse(operator2, out int value2) // if the operator2 is a number
                        return operator1.Substring(int.Parse(operator2), operator1.Length - int.Parse(operator2)); // desplaze it
                    else
                        return operator1 + operator2; // if not a number join the texts
                else
                    return (int.Parse(operator1) + int.Parse(operator2)).ToString(); // if a number the two sum it
            if (a == "-=") // the sub simbol
                if (
                    if (
                        return operator1.Substring(0, operator1.Length - int.Parse(operator2)); // desplaze it
                    else
                        return operator2; // if not a number return the operator 2
                else
                    return (int.Parse(operator1) - int.Parse(operator2)).ToString(); // if a number the two sum it
            if (a == "*=")
                return (int.Parse(operator1) * int.Parse(operator2)).ToString();
            return operator2;
        public async void
        ExecuteLimaScript
            string lscript,
            bool debug
            bool in_struct;
            string script = lscript.Replace("\r", "");
            string[] lines = script.Split(new[] { '\n' });
            while (
                Line_to_execute < lines.Length
                //Console.WriteLine(Line_to_execute.ToString() + ": " + lines[Line_to_execute]);
                if (
                    lines[Line_to_execute].Trim() == "@structure"
                    in_struct = true;
                    string structuredefinition = "";
                    while (
                        lines[Line_to_execute].Trim() != "}"
                        if (
                            lines[Line_to_execute].Trim() == "prototype"
                            if (lines[Line_to_execute + 2].Trim() == "var")
                                structuredefinition = structuredefinition + lines[Line_to_execute + 1].Trim() + "|" + lines[Line_to_execute + 3].Trim() + "\n";
                            else
                                structuredefinition = structuredefinition + (
                                    lima_variables[lines[Line_to_execute + 1].Trim()]
                                    Replace("|", "|" + lines[Line_to_execute + 3].Trim(
                        Line_to_execute++;
                    Line_to_execute++;
                    lima_variables[lines[Line_to_execute].Trim()] = structuredefinition;
                    in_struct = false;
                    //Console.WriteLine(structuredefinition);
                else if (
                    (lines[Line_to_execute]).Trim() == "mov"
                    //Console.WriteLine(Line_to_execute + 1.ToString() + ": " + lines[Line_to_execute + 1]);
                    globvars[(lines[Line_to_execute + 1]).Trim()] = LimaSyntax((lines[Line_to_execute + 2]).Trim(), debug);
                else if (
                        (lines[Line_to_execute]).Trim() == "ustruct"
                else if (
                    (lines[Line_to_execute]).Trim() == "org"
                    segments[int.Parse((lines[Line_to_execute + 1]).Trim())] = script;
                else if (
                    (lines[Line_to_execute]).Trim() == "if"
                    //Console.WriteLine("in if");
                    string if_condition;
                    if_condition =
                        (lines[Line_to_execute + 1]).Trim() + // (
                        (lines[Line_to_execute + 2]).Trim() + // ...
                        (lines[Line_to_execute + 3]).Trim() + // operator
                        (lines[Line_to_execute + 4]).Trim() + // ...
                        (lines[Line_to_execute + 5]).Trim() // )
                    Line_to_execute += 6;
                    //Console.WriteLine(if_condition);
                    //Console.WriteLine(LimaSyntax(if_condition, debug));
                    if (
                        LimaSyntax(if_condition, debug) != "false"
                        //Console.WriteLine("xd");
                        string popcode = lscript;
                        Dictionary<int, int> ppopback = popback;
                        string code = "";
                        int ele = 0;
                        while (
                                lines[Line_to_execute].Trim() != "}" && ele != 0
                            code += lines[Line_to_execute] + "\n";
                            Line_to_execute++;
                            if (
                                lines[Line_to_execute].Trim() == "{"
                                ele++;
                            if (
                                lines[Line_to_execute].Trim() == "}"
                                ele--;
                        if (
                            int popline = Line_to_execute;
                            popback.Clear();
                            ExecuteLimaScript(code, debug);
                            Line_to_execute = popline;
                            popback = ppopback;
                    else
                        //Console.WriteLine("yo");
                        int ele = 0;
                        while (
                            true
                            //Console.WriteLine(Line_to_execute);
                            Line_to_execute++;
                            if (
                                ele++;
                            if (
                                if
                                    ele == 0
                                    break;
                                else
                                    ele--;
                else if (
                    (lines[Line_to_execute]).Trim() == "var"
                    string name = (lines[Line_to_execute + 1]).Trim();
                    string op = (lines[Line_to_execute + 2]).Trim();
                    string value = (lines[Line_to_execute + 3]).Trim();
                    if (
                        (lines[Line_to_execute - 1]).Trim() == "[globalize]"
                        globvars[name] = Operate_With(
                            globvars.ContainsKey(name) ? globvars[name] : "",
                            op,
                            LimaSyntax(value, debug)
                    else
                        lima_variables[name] = Operate_With(
                            lima_variables.ContainsKey(name) ? lima_variables[name] : "",
                            op,
                else if (
                    (lines[Line_to_execute]).Trim() == "jump" ||
                    (lines[Line_to_execute]).Trim() == "jt" ||
                    (lines[Line_to_execute]).Trim() == "jf"
                    int section_search;
                    for (section_search = 0; section_search < lines.Length; section_search++)
                        if (
                            lines[section_search].Trim() == "section"
                            if (
                                lines[section_search + 1].Trim() == lines[Line_to_execute + 1].Trim()
                                if (
                                    if (lima_variables[".cnd"] == "false")
                                        popback.Add(popback.Count + 1, Line_to_execute + 1);
                                        Line_to_execute = section_search;
                                else if
                                    if (lima_variables[".cnd"] != "false")
                                else
                else if (
                    lines[Line_to_execute] == "popback"
                    if (popback.Count != 0)
                        Line_to_execute = popback[popback.Count];
                        popback.Remove(popback.Count);
                    else
                else if (
                    lines[Line_to_execute] == "__endprog__"
                    return;
                else
                    Execute(lines[Line_to_execute].Trim(), debug);
                Line_to_execute++;
            return;
¿te refieres a javascript? ¿Esta programado en python no? no manejo python, pero por lo que veo me parece a eso.
pero me sigo preguntando ¿cual es el objetivo del lenguaje? ¿hacer algo funcional? ¿o por solo entretenimiento? ¿a que esta destinado? ¿un lenguaje que soporte cualquier sistema? ¿que sea rapido y eficiente? o esa, ese tipo de cosas…
es que estoy interezado en lenguajes que me puedan correr hasta en windows 98… jaja, por eso ando preguntado.
si fuera por mi yo el lenguaje lo haria con la sagrada lengua castellana, digo, ya hubo mucho ingles, ahora nos toca a nosotros. pero bueno, si prefieres que sea adoptado, pues, si esa es tu intención pues haces bien por que es a lo que la gente se acostumbro
no es que el lenguaje esta hecho en C# puedes ver el codigo en ErickStudios/Lim22: the opensource version of lima
a chis… que bruto, ponganme cero.
no tampoco eso,pero si esta muy avanzado estoy implementando la funcion para hacer lo de las estructuras
apenas estoy aprendiendo los condicionales. no se que es una estructura
            if (
                in_struct = true;
                while (
                    if (
                        else
                    Line_to_execute++;
                Line_to_execute++;
                in_struct = false;
este codigo crea una estructura en mi lenguaje
y este codigo la usa
            else if (
                string var_set = lines[Line_to_execute + 1].Trim();
                string structure = lines[Line_to_execute + 2].Trim();
                string[] struct_use = lima_variables[structure].Split("\n");
                foreach (var item in struct_use)
                    if (
                        item.Contains("|")
                        string[] value_key = item.Split("|");
                        lima_variables[var_set + "->" + value_key[1]] = value_key[0];
respectivamente una estructura es una forma de organizar variables
por ejemplo :
en C/C++
struct Persona {
         CHAR16 Nombre[20];
         int Edad;
        void* trabajo;
y en mi lenguaje es
@structure
        prototype
        string
        var
             Nombre
        prototype
        int
        var
             Edad
        prototype
        void
        var
             Trabajo
Persona
¿que busca ser tu lenguaje? ¿busca ser sencillo de aprender o de utilizar? supongo que sera compatible para toda plataforma que tenga un compilador de c# ¿o es independiende de este?
es en C# y es un lenguaje muy facil de aprender ,pero cuando quieres comunicar tu programa con el interprete tienes que usar mov , “@eax” y “@bx” algo asi, un ejemplo es esta funcion intersegmental que controla funciones de el internet como obtener el contenido de una pagina o enviar algo a un servidor
###! net
[intersegmental]
message uefi_net()
    section
    Main
    var
        .cnd
    jt
        .recive
    var
        .cnd
    jt
        .send
    __endprog__
    # recive
    # Summary:
    # Params:
    # 	@_data1: the url
    # Registers used:
    section
    .recive
        mov
            @eax
            "/get-url"
        mov
            @bx
            @ScratchVar(_data1)
        %^"!p"
        if
            @ScratchVar(@ax)
            "unsupported"
            mov
                _returned
                "falied to fetch"
    __endprog__
    # MyFunction
    # Summary:
    # Params:
    # 	@_data1: the url
    # Registers used:
    section
    .send
        mov
            @eax
            "/send-set-url"
        mov
            @bx
            @ScratchVar(_data1)
        %^"!p"
        mov
            @eax
            "/send-url"
        mov
            @bx
            @ScratchVar(_data2)
        %^"!p"
        if
            @ScratchVar(@ax)
            "unsupported"
    __endprog__
[endmsg]
Bueno, bueno, estare pendiente al proyecto. Pero de momento, no entiendo nada. Apenas estoy entendiendo pascal :sweat_smile:
le puse comentarios por ti , para que pudieras entender que hace (xd estan en ingles los comentarios)
###! net
[intersegmental]
message uefi_net()
    # the main section of the message
    section
    Main
    # set the condicional var for execute the section recive if you want to recive
    var
        .cnd
    # jump if the condition is true
    jt
        .recive
    # set the condicional var for execute the section send if you want to send data to a server
    var
        .cnd
    jt
        .send
    # if nothing is true finish the function
    __endprog__
    # recive
    # Summary:
    # Params:
    # 	@_data1: the url
    # Registers used:
    section
    .recive
        # set the action for make
        mov
            @eax
            "/get-url"
        # set the url to request (in this case the _data1)
        mov
            @bx
            @ScratchVar(_data1)
        %^"!p"
        # check if the interpreter can make the action
        if
            @ScratchVar(@ax)
            "unsupported"
            # if not , set the return value
            mov
                _returned
                "falied to fetch"
    # end the message
    __endprog__
    # MyFunction
    # Summary:
    # Params:
    # 	@_data1: the url
    # Registers used:
    section
    .send
        # set the action to make (set the url)
        mov
            @eax
            "/send-set-url"
        # set the data to send to the url
        mov
            @bx
            @ScratchVar(_data1)
        # send the action to the interpreter
        %^"!p"
        # action for send the data
        mov
            @eax
            "/send-url"
        # now the data to send
        mov
            @bx
            @ScratchVar(_data2)
        # action!!!
        %^"!p"
        # if can make it
        if
            @ScratchVar(@ax)
            "unsupported"
            # ya puedes dejar de enviar datos, ya perdimos ;(
            # set the return value
            mov
                _returned
                "0"
    # the functions has been finished
    __endprog__
[endmsg]
Io no spiko inglis, yo puro español o esperanto
