un codigo en lima no puede ser tan largo, es un lenguaje simple
el codigo
# MKF7.lima
# abstract:
# because cant conect the debugger with the code this emulates it
# and because that "if dont have the tools of MKF7 make it by youself"
# please execute this before make anything in the uefi , basically its the uefi base
# save the code to the 0 segment (generally the lima base)
org
0
org
1
# for restore uefi and dont lose nothing
sendmw uefi_prototypes()
sendmw uefi_boot()
sendmw uefi_shutdown()
__endprog__
### ! A NEW SECTION WILL BE START SOON
######! MKF7 variables convertion
[intersegmental]
message uefi_prototypes()
[globalize]
var
_returned
prototype
[globalize]
var
_action
prototype
[globalize]
var
_data1
prototype
[globalize]
var
_data2
prototype
[globalize]
var
exit from boot services?
0
[globalize]
var
uefi recover segment number
1
[globalize]
var
_@zip.current_archive
"Z"
[endmsg]
######! prototypes
# prototype for uefi_fs
[prototype]
message uefi_fs()
prototype
[endmsg]
# prototype for uefi_arr
[prototype]
message uefi_arr()
prototype
[endmsg]
# prototype for efishell
[prototype]
message efishell()
prototype
[endmsg]
# prototype for uefi_boot
[prototype]
message uefi_boot()
prototype
[endmsg]
# prototype for uefi_shutdown
[prototype]
message uefi_shutdown()
prototype
[endmsg]
# prototype for uefi_reset
[prototype]
message uefi_reset()
prototype
[endmsg]
# prototype for uefi_exit_boot_services
[prototype]
message uefi_exit_boot_services()
prototype
[endmsg]
######! built-in MKF7 messages but implemented here
# intersegmental for make it a global message
###! shell commands
[intersegmental]
message shell_command()
#jt
# do_echo
if
@ScratchVar(_action)
"ls"
section
do_ls
# setuping
var
i
0
# get the array of the files
echo "in ls"
mov
@eax
"/glob -gtv -array_startswith"
mov
@bx
"Z>"
%^"!p"
var
list
@ScratchVar(_returned)
echo list
__endprog__
__endprog__
section
do_echo
#echo "in echo"
var
msg
var
msg
5
#echo msg
__endprog__
[endmsg]
###! uefi misc functions
[intersegmental]
message uefi_arr()
if
"0x0"
var
gx
Console.SizeX
var
gx
4
var
gx
2
var
gy
Console.SizeY
var
gy
2
#gotoxy gx gy
cecho "MKF8"
button_echo "the best know firmware solution builded in lima"
[endmsg]
###! net
[intersegmental]
message uefi_net()
# the main section of the message
section
Main
# set the condicional var for execute the section recive if you want to recive
var
.cnd
(@ScratchVar(_action)=="0x01")
# jump if the condition is true
jt
.recive
# set the condicional var for execute the section send if you want to send data to a server
var
.cnd
(@ScratchVar(_action)=="0x02")
jt
.send
# if nothing is true finish the function
__endprog__
# recive
# Summary:
# recive a content from a url
# Params:
# @_data1: the url
# @returned: the return value
# Registers used:
# @eax: for the commands
# @bx: the data send
section
.recive
# set the action for make
mov
@eax
"/get-url"
# set the url to request (in this case the _data1)
mov
@bx
@ScratchVar(_data1)
%^"!p"
# <- esto devuelve automaticamente el _returned
# check if the interpreter can make the action
if
@ScratchVar(@ax)
"unsupported"
# if not , set the return value
mov
_returned
"falied to fetch"
# end the message
__endprog__
# MyFunction
# Summary:
# send a data from a server
# Params:
# @_data1: the url
# @_data2: the data to send
# Registers used:
section
.send
# set the action to make (set the url)
mov
@eax
"/send-set-url"
# set the data to send to the url
mov
@bx
@ScratchVar(_data1)
# send the action to the interpreter
%^"!p"
# action for send the data
mov
@eax
"/send-url"
# now the data to send
mov
@bx
@ScratchVar(_data2)
# action!!!
%^"!p"
# if can make it
if
@ScratchVar(@ax)
"unsupported"
# ya puedes dejar de enviar datos, ya perdimos ;(
# set the return value
mov
_returned
"0"
# the functions has been finished
__endprog__
[endmsg]
###! diskload actions
[intersegmental]
message load_files()
echo "loading files..."
jump
Main
# only vfat12 , the subdirs cant be load
# this loads the files of your real pc in the path where is the uefi executable and coppy it to the
# Z hard disk
# Main
# Summary:
# the copy main
# Params:
# @(your files in the fd dir): for coppy to the virtual disk
# @(obiusly your personal files if you want): but is necesary for can put your files in the uefi
section
Main
# note: all changes maked to the files cant affect to the real file because this loads a
# coppy and not the real files, and lima only allows read but not write files and directorys
var
file_to_load
0
# get files count in the dir
mov
@eax
"/dir countf"
%^"!p"
var
max_files
var
max_files
1
jump
load
__endprog__
# load
# Summary:
# loads the files to the disk
# Params:
# @max_files: max files number
# @file_to_load: the start point of the files array to load
section
load
# declare vars
var
name
prototype
var
content
prototype
# get file information
# file name
mov
@eax
"/file_gName"
mov
@bx
file_to_load
%^"!p"
var
name
# file content
mov
@eax
"/file_gContent"
mov
@bx
file_to_load
%^"!p"
var
content
# create file
mov
"Z->"(..)name
content
echo "file "(..)name(..)" has been loaded."
var
.cnd
(file_to_load==max_files)
var
file_to_load
1
jf
load
# next file
__endprog__
[endmsg]
###! fs actions
[intersegmental]
message uefi_fs()
section
main
var
.cnd
jt
.uefi_current_fs_letter
var
.cnd
jt
.uefi_file_write
var
.cnd
(@ScratchVar(_action)=="0x03")
jt
.uefi_file_rename
var
.cnd
(@ScratchVar(_action)=="0x04")
jt
.uefi_file_coppy
var
.cnd
(@ScratchVar(_action)=="0x05")
jt
.uefi_file_get
echo "invalid file action"
__endprog__
# uefi_current_fs_letter
# Summary:
# gets the letter of the fs driver
# Params:
# nah
section
mov
_returned
@ScratchVar(_@zip.current_archive)
__endprog__
# uefi_file_write
# Summary:
# writes a file
# Params:
# @_data1: file name (including path)
# @_data2: file content
section
.uefi_file_write
mov
@ScratchVar(_@zip.current_archive)(..)">"(..)@ScratchVar(_data1)
@ScratchVar(_data2)
__endprog__
# uefi_file_rename
# Summary:
# renames a file
# Params:
# @_data2: new name
section
.uefi_file_rename
mov
@ScratchVar(_@zip.current_archive)(..)">"(..)@ScratchVar(_data2)
@ScratchVar(@ScratchVar(_@zip.current_archive)(..)">"(..)@ScratchVar(_data1))
mov
__endprog__
# uefi_file_coppy
# Summary:
# coppy a file
# Params:
# @_data2: file dest name
section
.uefi_file_coppy
mov
get{@ScratchVar(_@zip.current_archive)(..)">"(..)@ScratchVar(_data2)}
__endprog__
# uefi_delete_file
# Summary:
# deletes a file
# Params:
# @_data1 : the file name with path and extension
section
.uefi_delete_file
mov
get{@ScratchVar(_@zip.current_archive)(..)">"(..)@ScratchVar(_data1)}
__endprog__
# uefi_file_get
# Summary:
# get a file
# Params:
# @_data1: file full name
section
.uefi_file_get
mov
_returned
@ScratchVar(get{@ScratchVar(_@zip.current_archive)(..)">"(..)@ScratchVar(_data1)})
__endprog__
[endmsg]
###! loads a segment from the uefi
[intersegmental]
message uefi_load()
[endmsg]
# shutdowns the system
[intersegmental]
__endprog__
[endmsg]
# reset the system
[intersegmental]
sendmw uefi_boot()
sendmw uefi_segment_setup()
[endmsg]
# exit from bootservices
[intersegmental]
mov
1
org
0
# because the messages execute it as a independence code so , kill the orgiinal uefi segment (0) but
# dont worry a security coppy its mounted in the segment 1 for this cases
[endmsg]
###! the uefi shell
[intersegmental]
message efishell()
jump
loop
section
loop
writel "Shell> "
var
command
ReadLine
var
.cnd
(command=="exit")
jt
.exit
mov
_action
command
sendmw shell_command()
jump
loop
section
.exit
__endprog__
[endmsg]
###! the uefi routine
[intersegmental]
message uefi_boot()
mov
_action
"0x0"
sendmw uefi_arr()
sleep 1
sendmw load_files()
jump
main
section
main
mov
0
jump
loop
section
loop
writel "Boot From: "
var
prompt
ReadLine
if
prompt
"blk-1"
# the blk -1
sendmw efishell()
jump
loop
[endmsg]
contexto es el codigo de un firmware que estoy haciendo , se llama MKF8
