Class vs struct
cual es la diferencia? la verdad, las class tienen recolector de basura pero las struct no , las class suelen ser mas versatiles ya que permiten la herencia , las struct no
las class suelen ser mas usadas para frameworcks, por ejemplo
UiProt.lima
ui protocol tools, but for console/CLI
///! ![enable Lima++]
var
    GlobalTab
    0
UIFrameColor
represents the 16 posibles colors that a color can set
@structure
    Black
    represents the color Black
	prototype
    0
    var
        Black
    DarkBlue
    represents the color Dark Blue
    prototype
    1
    var
        DarkBlue
    DarkGreen
    represents the color Dark Green
    prototype
    2
    var
        DarkGreen
    DarkCyan
    represents the color Dark Cyan
    prototype
    3
    var
        DarkCyan
    DarkRed
    represents the color Dark Red
    prototype
    4
    var
        DarkRed
    DarkMagenta
    represents the color Dark Magenta
    prototype
    5
    var
        DarkMagenta
    DarkYellow
    represents the color Dark Yellow
    prototype
    6
    var
        DarkYellow
    Gray
    represents the color Gray
    prototype
    7
    var
        Gray
    DarkGray
    represents the color Dark Gray
    prototype
    8
    var
        DarkGray
    Blue
    represents the color Blue
    prototype
    9
    var
        Blue
    Green
    represents the color Green
    prototype
    10
    var
        Green
    Cyan
    represents the color Cyan
    prototype
    11
    var
        Cyan
    Red
    represents the color Red
    prototype
    12
    var
        Red
    Magenta
    represents the color Magenta
    prototype
    13
    var
        Magenta
    Yellow
    represents the color Yellow
    prototype
    14
    var
        Yellow
    White
    represents the color White
    prototype
    15
    var
        White
UIFrameColor
ustruct
    GUIColors
    UIFrameColor
IHBCanvas
represents the interface that contains the manage thins
collection<class IHBCanvas>
    Tab
    the current tab managen
    declare var<Tab>: any
IElementGUI
represents the interface of the ui elements
collection<class IElementGUI>
    XPos
    represents the x position of the object
    declare var<XPos>: number
    YPos
    represents the y position of the object
    declare var<YPos>: number
    Hidden
    if the object is not visible
    declare var<Hidden>: boolean
UIFrame
represents a frame
collection<class UIFrame>
    declare it as a class expansible of IElementGUI (its a type of herence)
    expand class IElementGUI
    SizeX
    the X size of the frame
    declare var<FSizeX>: number
    SizeY
    the Y size of the frame
    declare var<FSizeY>: number
    Background
    the background color of the frame
    declare var<Background>: number
UIRectangle
a ui rectangle (is a UIFrame but, drawable)
collection<class UIRectangle>
    expand class UIFrame
    Draw
    draw the Rectangle
    collection<function Draw>
        configure variables
        var
            XPosition
            (this)->XPos
        var
            YPosition
            (this)->YPos
        var
            IsHidden
            (this)->Hidden
        var
            SizeX
            (this)->FSizeX
        var
            SizeY
            (this)->FSizeY
        var
            Background
            (this)->Background
        configure the drawable text
        var
            Drawable
        var
            Drawable
            Repeat=
            SizeX
        var
            Drawable
            StrCat=
            %internal.linefeed
        var
            Drawable
            Repeat=
            SizeY
        gotoxy XPosition YPosition
        color 0 Background
        echo Drawable
    collection<end function>
UIText
a ui text element
collection<class UITextLabel>
    TextLabel
    the text label text
    declare var<TextLabel>: text
    Foreground
    the foreground color of the
    declare var<Foreground>: number
UIText
a ui text element
collection<class UIText>
    expand class UITextLabel
    Draw
    draw the text
        configure variables
        var
            XPosition
            (this)->XPos
        var
            YPosition
            (this)->YPos
        var
            IsHidden
            (this)->Hidden
        var
            SizeX
            (this)->FSizeX
        var
            SizeY
            (this)->FSizeY
        var
            Background
            (this)->Background
        var
            Foreground
            (this)->Foreground
        var
            Text
            (this)->TextLabel
        var
            Drawable
        var
            Drawable
            Repeat=
            SizeX
        var
            Drawable
            StrCat=
            %internal.linefeed
        var
            Drawable
            Repeat=
            SizeY
        color 0 Background
        echo Drawable
        color Foreground Background
        echo Text
IElementButtonUI
represents a UI button interface
collection<class IElementButtonUI>
    Code
    the code that is executed when you click the button
    declare var<Code>: any
    tab_id
    the id of the button in the tabulator
    declare var<tab_id>: number
UITextButton
represents a text button
collection<class UITextButton>
    expand class IElementButtonUI
    HoverBackground
    the background when the button is hoverd
    declare var<HoverBackground>: number
    HoverForeground
    the foreground when the button is hoverd
    declare var<HoverForeground>: number
    Draw
    draw the text
        Tab
        the current tab to check if select the button
        collection<param Tab>
        configure variables
        var
            XPosition
            (this)->XPos
        var
            YPosition
            (this)->YPos
        var
            IsHidden
            (this)->Hidden
        var
            SizeX
            (this)->FSizeX
        var
            SizeY
            (this)->FSizeY
        var
            Background
            (this)->Background
        var
            Foreground
            (this)->Foreground
        var
            HBackground
            (this)->HoverBackground
        var
            HForeground
            (this)->HoverForeground
        var
            Text
            (this)->TextLabel
        var
            TabID
            (this)->tab_id
        var
            Drawable
        var
            Drawable
            Repeat=
            SizeX
        var
            Drawable
            StrCat=
            %internal.linefeed
        var
            Drawable
            Repeat=
            SizeY
        color 0 Background
        if
            TabID
            color 0 HBackground
        echo Drawable
        if
            TabID
            color HForeground HBackground
        echo Text
    GoTo
    collection<function GoTo>
        lex (this)->Code
UIRectangleButton
represents a rectangle button
    HoverBackground
    HoverForeground
    Draw
    draw the text
        Tab
        configure variables
        var
            XPosition
            (this)->XPos
        var
            YPosition
            (this)->YPos
        var
            IsHidden
            (this)->Hidden
        var
            SizeX
            (this)->FSizeX
        var
            SizeY
            (this)->FSizeY
        var
            Background
            (this)->Background
        var
            Foreground
            (this)->Foreground
        var
            HBackground
        var
            HForeground
        var
            Text
            (this)->TextLabel
        var
            TabID
            (this)->tab_id
        var
            Drawable
        var
            Drawable
            Repeat=
            SizeX
        var
            Drawable
            StrCat=
            %internal.linefeed
        var
            Drawable
            Repeat=
            SizeY
        color 0 Background
        if
            TabID
            color 0 HBackground
        echo Drawable
    GoTo
        lex (this)->Code
UIGui
represents a GUI interface
collection<class UIGui>
    expand class IHBCanvas
    Items
    the items in the gui
    declare var<Items>: <class IElementGUI>[]
    Launch
    launchs the GUI
    collection<function Launch>
    AppendNewElement
    appends a new GUI item
    collection<function AppendNewElement>
        ItemPointer
        the variable of the item where the element is instanced
        collection<param ItemPointer>
    var
        (this)->Items
        Line+=
AppGUI
represents the global interface for all the application
collection<new class?UIGui AppGUI>
NULL
aqui como ven en algunos lenguajes como C y C++ o uno mas reciente lima no permiten funciones dentro de estructuras pero con los metodos de las class si permiten
si van a hacer proyectos grandes recomiendo class pero si van a hacer proyectos pequeños recomiendo struct
y sobre lo de lima , no es una promocion , solo es para que vean el poder de las class comparado con las struct
En esencia si te vas al concepto de estructura por ejemplo en C no pueden tener metodos herencia ya que su proposito es almacenar datos en un lugar comun como un contenedor, o cosas por el estilo lo del recolector de basura es cosa del lenguaje y no tiene nada que ver con las class o struct, las class añaden la herencia y el poder hacer metodos dentro de ellas por ejemplo en C++, tambien hay casos como el de Rust donde se puede usar la sentencia impl para implementar metodos a una struct, que haber en C puedes crear funciones que reciban la estructura en la que hacer algo como parametro y en Rust esto mismo aplica el impl y meterle ahi un metodo con self es basicamente para hacerlo más usable, y esto que te dije con el impl sale pues de conceptos que en lenguajes orientados a objetos como C++ o Java ya han explorado, la mayor diferencia es las clases permiten usar herencia para pasar de una definicion abstracta de un ente a definciones más especificas por ejemplo Vehiculo todos los vehiculos tienen cosas en comun pero hay vehiculos con caracteristicas distintivas por ejemplo algunos no tienen puertas, motos por ejemplo o cosas así y pues en el caso de las clases es bastante natural que se le puedan meter metodos salvo el caso de Rust que digo las struct por lo que se no lo permiten, perdon si ha quedado un poco largo tengo que reconocerlo hacer un lenguaje de esa manera es lo más eres increible
