[Arch] KDE Plasma
Dicen que siempre se vuelve a donde se es feliz, así que después de estar jugando un rato en Hyprland he regresado a mi escritorio predilecto, Plasma.
Con esta configuración, KWin casi funciona como un gestor tipo tiling. Va mejor de lo que esperaba xP
PD: Rayquaza, yo te elijo :stuck_out_tongue:
¿Me puedes pasar la config de fastfetch?
Curioso que el foro no acepte archivos tipo JSON
Bueno, aquí la tienes
  "$schema": "https://github.com/fastfetch-cli/fastfetch/raw/dev/doc/json_schema.json",
  "logo": {
    "type": "auto",
    "source": "~/.config/fastfetch/icons/icon_*.png",
    "width": 45,
  "modules": [
    "break",
    "break",
      "type": "os",
      "key": "OS   ",
      "keyColor": "red", // = color1
      "type": "kernel",
      "key": " ├  ",
      "keyColor": "red",
      "type": "packages",
      "key": " ├ 󰏖 ",
      "keyColor": "red",
      "type": "shell",
      "key": " └  ",
      "keyColor": "red",
    "break",
      "type": "wm",
      "key": "WM   ",
      "keyColor": "green",
      "type": "wmtheme",
      "key": " ├ 󰉼 ",
      "type": "icons",
      "key": " ├ 󰀻 ",
      "type": "cursor",
      "key": " ├  ",
      "type": "terminal",
      "key": " ├  ",
      "type": "terminalfont",
      "key": " └  ",
    "break",
      "type": "cpu",
      "format": "{1} ({3}) @ {7} GHz",
      "key": "CPU",
      "keyColor": "yellow",
      "type": "gpu",
      "format": "{1} {2} @ {12} GHz",
      "key": " ├ 󰢮 ",
      "type": "memory",
      "key": " ├  ",
      "type": "swap",
      "key": " ├ 󰓡 ",
      "type": "disk",
      "key": " ├ 󰋊 ",
      "type": "monitor",
      "key": " └  ",
    "break",
    "break",
Versión 1.5, diferencias… montones de transparencia pues pq sí :^
Quien te conoce, Hyprland
